Hello,
First.. thanks for all the help. I just purchased a new house that came with a fairly new looking whirlpool fridge with an icemaker on it. The other day I decided to run the water line to the fridge. As soon as i turned it on, water started pouring out from under the fridge. The connection is good and it's not leaking from there.
Any ideas on what it could be?
Many thanks again
Jason
Check all the water lines and connections to pin point exactly where the water is coming from.
Nat
Sorry my original post was so vague, but that's all I really have to go on. Could it be something internally that's come loose? Thanks for the reply
Jason
Again thanks.. I will check tonight when I get home.
Are there any repair manuals out there where I can see a diagram of the water line and trace it into the fridge? If so, I'll grab the model number when I get home..
Let's hope it's something that simple...
Jason
Post your model number and I'll check.
Nat
