hrmkr
#1 Posted : Wednesday, November 26, 2008 5:52:56 AM(UTC)
hrmkr
My refrigerator is not dispensing water. I recently replaced the filter. the ice machine is working fine.
I had this same issue about a year ago and my water line was frozen. Knowing this, I turned the temp up on my freezer to make sure the line wasn't frozen again and that did not help. I checked the water line inside the refrigerator part and it is not broken. I can hear a noise when I press the lever for wter but nothing comes out
HELP
Thanks for any advice
v2k04
#2 Posted : Wednesday, November 26, 2008 8:02:47 AM(UTC)
v2k04
well at least you know the solonoid is working or you wouldn't hear anything I suspect that it is frozen turning it off and opening the doors for 20 or so minutes usually clears it or maybe one of the lines broke in two and water is going on the floor under it and not leaving a trail for you to see unhook the connector right behind grill and blow through the line going into door and try calling for water with unhooked to see if water makes it to the point it was disconnected
abadfish66
#3 Posted : Wednesday, November 26, 2008 8:48:07 AM(UTC)
abadfish66
The part# to fix the freezing water line on the GE SxS refer made between 2003 and 2007 is WR49x10173
v2k04
#4 Posted : Wednesday, November 26, 2008 9:00:20 AM(UTC)
v2k04
Good One........thx
hrmkr
#5 Posted : Wednesday, November 26, 2008 8:30:29 PM(UTC)
hrmkr
I will try disconnecting the line in the morning. too tired now. What does part # WR49x10173 do?
thanks for all help
hrmkr
#6 Posted : Thursday, November 27, 2008 8:32:37 AM(UTC)
hrmkr
I disconnected the coupler and water was working. I turned off the freezer section and left the door open and now water is owrking properly.
From an earlier post, is there a way to keep the water line from freezing? I had the temperature at a level of 3 out of 5.
Thanks again for everyone's help
