outsider88
#1 Posted : Wednesday, November 26, 2008 4:59:40 AM(UTC)
outsider88
There is no water getting into the frig. I'm not getting any voltage at the solinoids when the drinking water switch is activated. No water to the ice maker or to the water filter either. I've tried to fined a wiring diagram for this unit but no luck. Are there any in line fuses or anything else I can check? Any help would be appreciated.
v2k04
#2 Posted : Wednesday, November 26, 2008 8:20:40 AM(UTC)
v2k04
check the connection in the left door hinge there are no in line fuses
outsider88
#3 Posted : Wednesday, November 26, 2008 7:06:14 PM(UTC)
outsider88
Is the voltage to the soliniods suposed to 120 V. or is there a transformer in the circuit somewhere? I want to put power directly to them to make sure they work but I'm unsure of the voltage. Thx
v2k04
#4 Posted : Wednesday, November 26, 2008 7:42:07 PM(UTC)
v2k04
yes the water fill vale is 120
