raycharn
#1 Posted : Monday, November 24, 2008 1:11:16 PM(UTC)
raycharn
My GE dryer model DX4500EA1WW will not stop drying. For start I thought it was the timer( because it stay at the same spot it start), but after a brand new part replaced, it still act the same. the timer seem to stuck wherever it start. I'm now not sure that it's the timer or anything else, please help.:confused:
Drags1998
#2 Posted : Monday, November 24, 2008 1:49:53 PM(UTC)
Drags1998
Put the dryer timer on the TIMED DRY cycle, Does it move on this cycle? If it does, Pull it apart and check the heating element, I'll bet that 1/2 of the element is broken!!!:)
raycharn
#3 Posted : Tuesday, November 25, 2008 5:37:00 AM(UTC)
raycharn
In deed the timed dry cycle is working perfectly good. Only the automatic part that's not function. I'll check the element and report back.
Big THANKs,:D
Guest
#4 Posted : Monday, May 6, 2024 7:21:38 AM(UTC)
Guest
Rank: Guest
United States
Hello, I have a GE DWXR473ET electric dryer that has simple and all mechanical switches/controls with no humidity sensor or any complicated electronics, etc. The only problem it recently started having is that the timer won't run for the 2 automatic drying functions. So if the main function switch is at the position for automatic cotton drying cycle, the dryer will just keep running nonstop till I turn the switch to interrupt it. However, it runs great for both "Extra Care" and the "Timed Dry" operations. All other switches and internal thermal switches have been tested functional. I even replaced the main function selector / timer switch and it didn’t fix the problem. So that might indicate that the problem is not with the timer itself (which I had considered to be the main culprit). I just cannot imagine what else can be defective to cause the problem. I wonder if you could give me some advice as to what might cause the problem so I can buy the right part. Any suggestions or opinions will be greatly appreciated. Thanks.
