I'm not actually sure how old this dryer is. The drum turns. I ran the thing with the door open in the dark thinking I'd be able to see the elements glowing but I did not. Didn't feel any significant airflow either. I've run a multimeter between all of the connections i could find on the back of the thing and the needle jumped for all of them except for one. I think it's the thermal fuse but I'm not certain. What other information would be helpful?
PS: I think the vent hose was the cause of the problem it was chewed up pretty bad in a couple of spots.
PSS: I need a parts breakdown of my machine so that I can tell for sure what part doesn't have continuity...any help would be appreciated.
