Hi, my dishwasher works great, however, the big fat plastic screw that holds the upper arm to the hub broke and I have been unable to find a replacement. I was going to get the entire package but the person I chatted with said the kit includes the hub, arm and washer (which I already have) but not the screw, which is what I need. I have tried metal screws but they do not seem to howl all the parts together. What should I do?
Originally Posted by: Mita  Hi, my dishwasher works great, however, the big fat plastic screw that holds the upper arm to the hub broke and I have been unable to find a replacement. I was going to get the entire package but the person I chatted with said the kit includes the hub, arm and washer (which I already have) but not the screw, which is what I need. I have tried metal screws but they do not seem to howl all the parts together. What should I do? Mita, This is the upper most spray arm assembly, the one mounted to the top of the tub, correct ? If that's the case, This should be the screw you're looking for, Part number: AP3669304
Good Luck, :) :)
