Paul E.
#1 Posted : Monday, December 27, 2010 12:52:50 PM(UTC)
Paul E.
no water for final rinse cycle, motor runs a long time. originally thought it was the drain cycle until I added some water then heard the rinsing swish sound.
Joe / APP Team
#2 Posted : Tuesday, December 28, 2010 12:17:57 PM(UTC)
Joe / APP Team
Paul,
Sounds like a bad fill valve (cold water solenoid) or maybe the hose and valve screens are clogged with debris or sediment, it could be the water faucet is off,as well ?
Or at least, that's were I'd start,
You wouldn't notice that in the wash cycle fill, the rinse cycles are automatically Cold fill in most washers nowadays.
A proper model number would have been more beneficial, but not to worry,
I'm pretty sure you'll find the problem in the above mentioned checks.
