A piece of plastic straw went in the area below the lower sprayer arm and is causing a thumping sound when running. How do I remove the sprayer arm so I can check underneath?:confused:
I believe it is lift and rotate it counter clockwise. |
THIS FORUM IS DEAD!!!!!!! |
