leon
#1 Posted : 18 years ago
leon
I have a gas oven with digital controls. When I set the control to bake at 300 degrees it ignites and heats till the display reads 300, but the actual oven temp is only 130. The sensor resistance is about 1100 ohms at room temp.
Can anyone help?
thank you,
leon
Pegi
#2 Posted : 18 years ago
Pegi
How long are you letting it heat, see what the temp is inside of the oven after it cycles several times, check it after 30 minutes to see if there is a problem or not...
leon
#3 Posted : 18 years ago
leon
It does not matter how long I leave it on, it cycles and controls the heat only the actual is way lower than the display.
thanx for the reply
leon
