Have you purchased motor (pump) part# 154582601? This is the replacement motor for several Kenmore and Frigidaire dishwashers. The metal shaft of the motor has a plastic piece pressed onto it. If you have an undamaged plastic part I would like to buy it from you. It looks like this:
Note manufacturer authorized substitution: Motor 154582601 may differ in appearance, but is a functional equivalent to prior parts including 154449601. SirNewton attached the following image(s):
looking for same plastic part
