I replaced the burner tube, ignitor and safety valve in my oven. Now when the oven is on the top burners barely work and the oven is full of soot. What's the problem?
Originally Posted by: bigronm  I replaced the burner tube, ignitor and safety valve in my oven. Now when the oven is on the top burners barely work and the oven is full of soot. What's the problem? I figured it out. The brass fitting on top of the safety valve has to be screwed in the entire way to convert it to propane.
