Found 1" water not draining after cycle. Blew out drain lines but then I found that I could not start the unit to check it. Have main power coming into unit but the control panel won't work and no lights illuminate. What could be the problem?
Here are your parts Replacement parts for KENMORE 66513592K600 | AppliancePartsPros.comI am assuming that when you checked for power it was after the wirenuts that may connect the unit to the line. It could be the thermal fuse is blown. It is about a third of the way down the first page of the parts. It is attached or on the control board. If blown be sure to use the new harness which comes with the fuse. Also check your door latch switches. There seems to be a rash of units with no power, this is the third one I have seen today. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here are your parts Replacement parts for KENMORE 66513592K600 | AppliancePartsPros.comI am assuming that when you checked for power it was after the wirenuts that may connect the unit to the line. It could be the thermal fuse is blown. It is about a third of the way down the first page of the parts. It is attached or on the control board. If blown be sure to use the new harness which comes with the fuse. Also check your door latch switches. There seems to be a rash of units with no power, this is the third one I have seen today. Is there a way to check the control fuse with a meter? I tried checking ohms and there was no continuity.
If there was no continuity it is open and blown. |
