AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore elite would not drain it make clanky noise
My Kenmore works fine up to drain start making this clanky noise TekTek,.. from the motor or some thing else , not sure ,, I checked the pump and it seems fine. any help would be great,,
Did you check inside the pump? Please post your model number.
Nat
Originally Posted by: libertyappl  Did you check inside the pump? Please post your model number.
Nat Yes I took the pump out and turn it few time, it seems Ok. I do not see the model any where. Kenmore with touch pad, digital timer, elite Catalyts. this all what see.
The model number is located around the opening where the clothes go in.
Nat
Originally Posted by: libertyappl  The model number is located around the opening where the clothes go in.
Nat Model no. SM 9710768-C
Could be the motor coupler (most likely), or something stuck between the inner and outer tubs.
Washer Repair
