Hi, My Kenmore dishwasher soap door won't open during the wash. I can open it by hand,nothing seems broken,the latch opens when I press it,can anyone help ? Thanks, Kathy
Kathy, can you post the rest of your model number, there should be about 8 more numbers.
Nat
Hi Nat, The serial # is 15522000,type 280-1. Thanks , Kathy
You are probably going to need to open the inner parts of the doo up and check the actuator and spring that opens the soap dispenser door. If you need to see a parts diagram go to searspartsdirect web site and type in your model number 66515522000 Nat
