I just purchased a replacement motor for my dryer, LGR5634AW0. It did not comes with instructions. How do I replace it?
Wow...thansk so much. Do you happen to have the timer manual? I removed the wire to open the top and might hve installed it wrong. Now my dryer won;t shut off.
All timer terminals are marked according to the wire colors. Like BK - black, R- red etc.
Ok, so the fact that my timer still ticks even on the off means my timer is bad? It bypasses the timer cycle, continues to the Fluff cycle and only stops on the off on the Fluff Cycle. Does this mean I need a new timer? It was working perfectly before I replaced the motor.
Ok, i read it might be the push start button. Any manuals on how to wire the push start -button correctly?
