Getting error code F-3 when trying to use oven, convection fan runs continuosly heat sensor appears to ohlm out good, have replaced Relay board with no change. what should I try now??? main board??
Check the wiring to the sensor.... Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nat
