When turning on the front right (larger) solid burner element TO ANY TEMPERATURE SETTING, the burner comes on very high and I notice an odor. The right back (smaller) solid burner element appears to work correctly except sometimes the burner light comes on and may go off - it's "touchy". Since I have two solid burner cartridges and both are exhibiting this problem, I assume it's not the cartridge but something behind the control knob, but what part am I looking for? Based on the Internal Controls diagram, I suspect it could be either AP4291987 or AP4291988.
After additional searching in this forum, I think I was looking at the wrong diagram. It would seem the part that needs to be replaced is the infinite switch AP4088188.
