johnnydoughey
#1 Posted : Saturday, November 22, 2008 7:37:00 AM(UTC)
johnnydoughey
When agitating, the machine squeeks at the moment it changes direction. It sounds like either a belt or plastic part rubbing and/or losing grip. I can cause it to repeat this when I have the top off and manually move the drum. However, I have not found an actual belt on the machine and do not know how to take the agitator off to check further. Does anyone know where a manual canbe found... or the solution?
thanks much...
Bill McGuire
libertyappl
#2 Posted : Saturday, November 22, 2008 8:27:35 AM(UTC)
libertyappl
If you have the top off, remove the front panel as well and you can see under the tub.
nat
johnnydoughey
#3 Posted : Saturday, November 22, 2008 6:22:14 PM(UTC)
johnnydoughey
Thanks for the info...
I had the front off and did notice a thick rubber bushing that the tub went through. I used a silicone spray on it and th noise has subsided. I'll spray it a couple more times to see it it disappears...
Thanks again...
