5 yrs old don't believe ignitors bad but broiler works oven doesn't gas does not come on besides control panel could it be anything else help
Originally Posted by: ron122010  5 yrs old don't believe ignitors bad but broiler works oven doesn't gas does not come on besides control panel could it be anything else help Ron, You most likely have a weak or bad bake burner igniter, Part number: AP2014008
If you have a multi meter, check for 120 VAC at the bake burner igniter wires, comong from the chassis, not the wires on the igniter, when you program a bake cycle and a temperature. If you have the 120 VAC, on the wires, then your control is OK, Just because a glow bar igniter glows, doesn't mean it's working properly. When the glow bar glows, it has to produce a specific amount of amperage and a low voltage circuit to the gas valve( in your case 2.5 to 3.2 amps and 2.5 to 3.2 VAC at the gas valve terminals) if the glow bar is weak, it won't produce the required circuits and the burner won't release gas, and ignite. I would start there, if I were you. :cool: :cool: :cool: Happy Holidays :) :) :)
