how do i replace oven glass (inner)
Originally Posted by: martyknite  how do i replace oven glass (inner) Marty, Here's a step by step general teardown procedure for your style KA Range. I take for granted you've already orderred the inner glass ? Good Luck, :) :) :) 1. Remove the oven door from the range 2. Place the oven door on a padded work surface with the decorative glass and handle facing up and the bottom edge facing the front. 3. To remove the decorative glass and handle:
a) Remove the screw from each of the two decorative glass retainers, and remove the retainers. b) Turn the door 180ー so the handle faces the front. c) Remove the two door handle bracket screws. d) Lift the bottom of the decorative glass and slide it down so the top clears the lip of the liner, then lift the glass and handle off the door liner assembly
e) Remove the two door handle screws from each of the brackets and remove the handle from the decorative glass. f) Remove the two hex nuts from the decorative label and remove the label. g) Remove the decorative glass from the frame.
4. To remove a hinge:
a) Remove the decorative glass and handle from the door liner (see step 3). b) Position the oven door liner with the inner glass facing up. c) Remove the two screws from the left or right hinge you are servicing. d) Lift the door liner and remove the hinge.
5. To remove the two pieces of outer oven door glass:
b) Position the door liner with the outer oven glass facing up, as shown. c) Remove the two screws from the lower bracket for the outer oven glass. d) Slide the lower bracket off the first piece of outer oven glass, then slide the glass out of the top retainer tabs
e) Remove the three screws from the top retainer and remove the retainer from the liner. 6. To remove the inner oven door glass:
a) Remove the decorative glass and handle from the door liner (see step 3). b) Remove the two hinges (see step 4). c) Remove the first piece of outer door glass (perform steps 5b through 5d). d) Remove the two inner door liner screws and lift the inner liner off the outer liner.
f) For the second piece of outer oven glass, remove the two screws from the left bracket, then remove the bracket and second piece of glass from the door liner.
e) Lift the inner oven door glass off the outer liner
