Yesterday I had to wait one hour and a half for my oven to heat up to 350 degs... What is wrong??? Never had this problem before. HELP:(
A model number may help others help you. Model Number LocatorDo both elements work? Could be that either the bake or broil element is burned out. |
THIS FORUM IS DEAD!!!!!!! |
I didn't look to see if the broil element worked was no aware that the broil turns on to heat up the oven.. The bake at the bottom was lite. I will check the broil.
