Lately the dishwasher does not always fill with water. It will run the entire cycle if I don't catch it. It was working the second time. Now it seems to take 3 tries to get it to fill with water. Sometimes it is just fine. What is most likely the cause?
Your model number seems to be short a few digits, Here are parts breakdowns. Replacement parts for DU1148 models | AppliancePartsPros.comSounds like it happening fairly often. I would check for voltage across the water valve when it should be filling. If you have 120 volts and the valve does not open then the valve is your problem. |
THIS FORUM IS DEAD!!!!!!! |
