dallin robinson
#1 Posted : Sunday, December 19, 2010 6:12:10 PM(UTC)
dallin robinson
The Oven Will Turn On And Warm Up To The Set Temp. Then During The Cooking Time The Oven Burner Will Not Reignite To Keep The Set Temp. If I Then Turn The Oven Off And Back On It Will Ignite And Work Proberly For A Period And Then The Problem Will Return During The Cooking Process. The Problem Does Not Alway Happen Some Times It Will Work For The Entire Cooking Time And Sometimes It Will Not. Any Ideas?
Joe / APP Team
#2 Posted : Monday, December 20, 2010 1:49:56 PM(UTC)
Joe / APP Team
Dall,
A couple of things to check,
The bake burner, check and make sure all the port openings are clean, especially the ports in the spark ignition area.
Make sure the burner is properly located and screwwed in place(at the front of the oven).
Check the wire at the spark igniter for loose and check it back to the gas valve,
Check the Blue and Orange wire at the gas valve for loose connections,
If all checks are OK, and the burner ports are clean,
Replace the DSI Spark Module, in the control panel
Part number: AP3672576
Good Luck,
Happy Holidays,
Viking Oven will not stay on (Oven Repair (including Ranges and Cooktops))
by Arlington22207 11/10/2013 4:19:02 PM(UTC)
Maytag Gemini beeps and middle oven will not stay on (Oven Repair (including Ranges and Cooktops))
by enzy216 11/25/2012 3:39:09 PM(UTC)
