markham
#1 Posted : Friday, November 21, 2008 5:41:13 AM(UTC)
markham
I had this washer apart about a month ago to repair/replace the transmission.
Everything shifts, cycles and runs as it should. However, the machine now has a very tough time balancing loads before the spin cycle. If there are jeans or towels in there... forget it. We have to pull the items out and then put them evenly around the tub before the spin cycle will run right.
The top of the tub seems to move around more than it used to, so I'm wondering if I didn't put something back just right. I can't really tell from the diagram.
abadfish66
#2 Posted : Friday, November 21, 2008 8:29:58 AM(UTC)
abadfish66
If the tub seems loose, your hub nut may have come loose, take off the agitator, and the coupler and see if it is on good and tight.
