Here are the parts
Replacement parts for KENMORE 11066662501 | AppliancePartsPros.comIf you go to the Sears parts site they have part breakdowns.
[COLOR="Blue"]
Dryer turns, but suddenly no heat. Perhaps it's the dryer thermal fuse? Literature says fuse "is located on the blower wheel cover." Where is that located?[/COLOR]
This is inside the unit by the motor.
This will not be your problem as this fuse kills power to the motor.
It could be the thermal cut-off (fuse) mounted on/close to the heating coil.
If this is blown there are other things that have to be checked before replacing it.
Also could be the heating coil is burned out.
Remove the rear cover to see the above.
The first thing to check is power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
The heating coil requires the full 240 volts.
Here is a link with basic dryer repair help.
http://www.applianceaid.com/dryers.htmlIf you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
