3 Pages123>
russ1
#1 Posted : Thursday, November 20, 2008 2:20:28 PM(UTC)
russ1
my washer filled and while filling another item was added. when the lid was reclosed, the washer failed to restart. I have removed the lid switch and tried to test it. Not sure I'm reading the meter correctly...please help. MODEL NUMBER IS LAT9356AAE
libertyappl
#2 Posted : Thursday, November 20, 2008 2:26:46 PM(UTC)
libertyappl
Double check your model number it doesn't pull up
Nat
russ1
#3 Posted : Thursday, November 20, 2008 2:28:25 PM(UTC)
russ1
lat9356aae maytag...mfg date 1997
libertyappl
#4 Posted : Thursday, November 20, 2008 2:33:07 PM(UTC)
libertyappl
The part number you will need is AP3470229
Nat
russ1
#5 Posted : Thursday, November 20, 2008 2:34:07 PM(UTC)
russ1
do you think the lid swith is bad....i tried to test it with a meter and i am not sure im doing it correctly
libertyappl
#6 Posted : Thursday, November 20, 2008 2:40:52 PM(UTC)
libertyappl
Most likely, If you can find your wiring diagram it give a lot of that information, should be inside the control panel.
Nat
russ1
#7 Posted : Thursday, November 20, 2008 2:42:50 PM(UTC)
russ1
i have it...what are you looking for on it?
libertyappl
#8 Posted : Thursday, November 20, 2008 2:50:01 PM(UTC)
libertyappl
Let me take a look
Nat
russ1
#9 Posted : Thursday, November 20, 2008 2:55:19 PM(UTC)
russ1
i think i can scan this and email it to you..what is your email
libertyappl
#10 Posted : Thursday, November 20, 2008 2:58:32 PM(UTC)
libertyappl
I found it online...
Ok You need to test for continuity between where the yellow & light blue wires attach and the white & light blue. You will need to activate the switch open & closed while testing.
Post what you get.
Nat
3 Pages123>
