Hi All,
I've been trying to look for the wiring diagram for these two parts( PTCR & Overload) to no available. I need to connect them back together, so I will have a working fridge again :(
Can anyone please help?
Thanks in advance!
The black goes to the overload, and orange or orange and white goes to the ptc... Some models have just orange to the ptc, and some have an orange and a white wire to the ptc...orange on the left and white on the right.
Be careful, if you hock up the wires incorrectly you may burn out the compressor. You will need an ohm meter to verify which compressor terminals are run, start and common. If the factory service part is one piece, you will have no problem replacing the start device.
