Ed M
#1 Posted : Thursday, December 16, 2010 2:31:05 PM(UTC)
Ed M
I spent 15 minutes writing a message and it refuses to post it even though I registered and it shows me as logged in. What is the problem?
Ed M
#2 Posted : Thursday, December 16, 2010 2:33:02 PM(UTC)
Ed M
well it worked the second time - weird
Ed M
#3 Posted : Thursday, December 16, 2010 2:43:33 PM(UTC)
Ed M
My Ge refrigerator water dispenser stopped working. The ice maker works fine.
I opened the plate att he back bottom of the refrig and checked the water valve at the back of the refrigerator and water comes out of the blue solenoid when i press the dispense flap on the door.
I then reconnected the line to the blue solenoid and took the grill off the bottom front of the refrig. I found a line that goes into the freezer door at the bottom hinge- looks like the water line. I disconnected the line at the quick connect fitting at the bottom of the door - no water comes out of this line when i press the dispense flap.
Then i went to the back and disconnected the line from the blue solenoid. then i went back to the front of the refrig and blew into the end of the line i previously disconnected there - but nothing came out of this line at the back of the refrig.
So- is there something else to look for? help please.
Ed M
