KINGKONG
#1 Posted : 16 years ago
KINGKONG
There is a small white plastic srew on the left side of this icemaker...what does it do...?cube size?
v2k04
#2 Posted : 16 years ago
v2k04
The screw is for "you guessed it"!! Ice cube size, but it will only adjust so far. the icemaker is on a time fill so by adjusting the screw counterclockwise you increase the amount of time the water goes in. The proper amount of water is 2/3 cup but a person can get by with a 1/2 cup 1/2 turn = 20cc or 1.2 sec full turn = 40cc or 2.4 sec max adj is one full turn either direction
