Replacement parts for KENMORE 11096585200 | AppliancePartsPros.comAll the below parts are shown on the first page of the parts.
First check the power, then the heating element, then the heater's thermal fuse, then the hi-limit thermostat and finally cycling (main) thermostat.
There are other parts that can cause no heat but checking them gets more complicated.
You do not have to worry about the thermal fuse (white plastic) on the blower as this kills power to the motor.
The heating element should be around 10 ohms.
All fuses and thermostats should be 0 ohms.
Note: Your cycling thermostat has 4 wires. 2 are the contacts and should be 0 ohms. The other 2 are an internal heater (turns on to lower the operating temperature for low temp settings), should be around 25,000 ohms. It is also mounted on the blower.
The heater's thermal fuse and hi-limit thermostat are mounted close/on to the heater assembly.
If the heater's thermal fuse is blown get back to us as there are other things to check. As you can see it comes with a new hi-limit and the hi-limit should have regulated the temperature to prevent this fuse from blowing.
Power CheckTry flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
