I need help or directions with the replacement of the glass top to my Jenn Air electric stove. I have a broken top and have ordered the replacement glass. How do I take the old glass out and replace the new one? Are there screws I should be looking for? Aby help or locations to find some good directions would be helpful.
The service manual that covers JES8750BAS, also covers among other models the JES9800BAS. If you follow the link below, there is a post where Gene, a senior expert, posted an attachement that describes the procedure for the Maintop Assembly - downdraft cooktops. That procedure applies to your model also. http://forum.appliancepartspros...lacement.html#post309767Good luck, Dan
