model # kebc208kss0- double oven. I need to replace door latch assembly on bottom oven,how do I seperate the two,(black screws on the side bracket or is there more).
:confused: Originally Posted by: Ramm  model # kebc208kss0- double oven. I need to replace door latch assembly on bottom oven,how do I seperate the two,(black screws on the side bracket or is there more).
THIS FORUM IS DEAD!!!!!!! |
