Hi
I have a problem that is about 12 years old. The oven brand name is Frigidaire, model number (RE686ED-1). I was using the oven one night and control panel was not working. I couldn't turn off the oven, so i unpluged it. When i repluged in the oven all i got was (Error F3) and the control panel was not working. Can someone tell me what (Error F3), and what i can do to fix? I haven't been able to turn on the oven ever since.:( :( :( :(
Thank you,
Generally F3 points to a bad sensor if the sensor doesn't correct it The board is bad
