When I fill up the tub in the washer to XL with nothing in it it's fine but as soon as I put clothes into it the water splashes out of the top (tub cover) through the little port holes. It's enough water to leak down the inside of the washer tub to get the floor soak. And this only happenes when the washer is washing (agiator is going) not when it is spinning out.
Could anyone give me any help on this. :D
If you put the cloths in FIRST, You wont have this problem.Its My opinion that cloths should always go in first. If you try this and it still leaks, Replace the water level switch.:)
I have put the cloths in first and let it fill up and it still pushes the water up out of the port holes and through the bleach despenser as it starts to agiate. Have tried it both ways with and without cloths, with just water, no problem as soon as I add cloths it spits out the water.
I would replace the water level switch:)
