jklmkeeler
#1 Posted : Monday, November 17, 2008 1:22:07 PM(UTC)
jklmkeeler
I recently purchased a dual infinite switch kit to replace a
defective switch (part# AP3471267)on a Jenn Air CCE3400W stovetop (ser# 11879086MD) The original switch had 5 wire connections, the new part has eight. Do you know the proper way to wire up this switch? I need to connect a blue line (old switch terminal4) goes to the outer burner. Purple (3) also to outer ring. Red (top terminal labled N) which is a compound line going to both the inner ring, and to the left front switch. Black (2) witch is also a double line, one going to the left front and the other straight to the fuse box. Orange (5) witch goes to the light.
thanks...
jklmkeeler
#2 Posted : Tuesday, November 18, 2008 1:04:52 PM(UTC)
jklmkeeler
No help out there?
