Dryer was working the other day when I was doing laundry, and today the dryer spins but no heat. :( 240v dryer it has enough power to the dryer. I was thinking about the heating element or the thermostat? If any body has had this problem before I was wondering how you solved your problem.
Frigidare Dryer Model # de5800aww1 Serial # xd40405990
Thanks, George120
It is most likely the heating element, and on that model, the top comes up the front comes of the drum comes out to get to the element. The only other thing that happens to that model, is sometimes the wires burn up, where the cord goes into the dryer. Tom ApplianceEducator.com
