Drew 85379
#1 Posted : Wednesday, December 8, 2010 2:14:18 PM(UTC)
Drew 85379
A few months back I noticed what appeared to be glue or paper stuck to ice cubes in my ice bin. Ever since, My ice maker seems to have a slow leak while filling the ice maker and in turn it is causing all my ice to stick together into one large cube. I thought I found the leak and placed a small cup to catch it but found that is is doing it in other places. I don't see the leak but find the bin frozen together due to water flowing. Is it feeding too much water? Is this a simple fix? Will the entire unit need to be replaced? What parts do I need?
Joe / APP Team
#2 Posted : Thursday, December 9, 2010 9:16:57 AM(UTC)
Joe / APP Team
Drew,
Normally, with your complaint and description I would reccomend you replace the fill valve on the back of the refrigertor.
(there are two possible parts based on series number)
AP4080862
AP4080917
You should also check and/or replace the water filter if you haven't yet.
AP4343647
A clogged, dirty filter can reduce the water pressure in the system, and low water pressure can cause a fill valve to seap/drip.
What I'm wanderring is, you stated you " found it is doing it in other places " A leak I presume , but in what other places ???
Hope to hear from you soon,
