Roeboat109
#1 Posted : Sunday, November 16, 2008 6:34:04 PM(UTC)
Roeboat109
Im not sure how old it is.
When it is tumbling it makes a lot of noise not like a belt. If its drum rollers,how hard are they to replace? If its not that what does anyone recommend?
magician59
#2 Posted : Monday, November 17, 2008 6:05:02 AM(UTC)
magician59
If the noise is a low pitched rumble, it's probably the roller supports. They are easily replaced; they're attached to their posts with "Truarc" snap rings. When you replace them, just wipe the posts clean. Do not add any lubrication to them. It's a good idea to also replace the idler pulley and the belt for good measure while you have the dryer apart. This is just preventive maintenance.
