Replacement parts for WHIRLPOOL KSRG25FKBL02 REFRIGERATOR | AppliancePartsPros.comI am assuming that by running you mean that the compressor, the condenser (compressor) fan and the evaporator fan are all running.
Try to isolate where the smell is coming from. This may not be possible.
I would remove the cover inside the freezer so you can inspect the evaporator coils etc.
Perhaps the unit went into a defrost cycle and the defrost thermostat (Item 35 in Section 11) did not turn the heater off when the ice was melted off the coils.
Check for any signs of overheating.
The defrost thermostat should open just above freezing.
It can be checked with a meter. Place it's face onto an ice cube to freeze it.
It should close and be 0 ohms.
Then let it warm up and it should open (infinite ohms).
Also if it is bulged out or deformed it needs replacing.
Check that both fans are OK as they may be the source of the smell.
If the evaporator fan is not working the fridge side will not cool. The fan pushes cold air into the fresh food side.
It will take the fresh food side considerably longer to cool down.
Check that the damper (item 24 in Section 2) is open allowing cold air into the fresh food side.
I would not trust this unit until you can locate and repair the cause of the smell.
It may even be a fire hazard.If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
