The unit does not stop filling regardless what size setting.
Your pressure switch maybe out ot the tube may have a crack, pin hole or water in it. Or your valve just stuck open.
Nat
While it's filling, unplug the machine. If it continues to fill, the problem is the water inlet valve.
