scooter m
#1 Posted : Sunday, December 5, 2010 5:09:50 PM(UTC)
scooter m
My Kitchen aid fridge/freezer is not working. The model # is KSRD22FKBT14. The compressor is very hot to the touch. I took the below part off and the white piece shakes like it is broken in the inside. Any thoughts on if this is the only part needed to be replaced? Pics of it below...
thank you!
scooter m attached the following image(s):
#2 Posted : Monday, December 6, 2010 1:23:39 AM(UTC)
I would replace the start device with AP3885081. Comes as a kit. I would use the separate small, black start device and the separate overload klyxon, small thin device. Both items are more reliable than the old one.
#3 Posted : Monday, December 6, 2010 2:03:56 AM(UTC)
When you say the unit is not working do you mean that there is no coolinfg at all re: no frost on the evaporator coils.
That the compressor is hot seems to indicate that it is getting power.
Is it vibrating?
If you let the compressor cool down, will it start up?
Is the condenser (compressor) fan running?
Here is a good site with info on how to check components.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
I would check the compressor windings.
Note: That if both windings check out OK it does not eliminate the compressor as the problem. It could still have internal mechanical problems.
But if one of the coils is open or shorted to the case then you know that it is toast.
