The dispenser assembly door is broken and no longer shuts when soap is applied. Not sure if this is a big deal or not, but was thinking of replacing it. I can find the part easy enough (AP3776575), but do not know how to remove old one and install new one. Do you take off the outer or inner door panel, and how do you do it. The inner panel seems to unsrew with Torx screws, but I am not sure how to take out the outer door panel if that is the best way to unscrew it and replace it. Any help?
I believe I found another thread with a similar service manual and instructions. This is a great website! Thanks to all of you experts! Jay
Originally Posted by: jaybgator  I believe I found another thread with a similar service manual and instructions. This is a great website! Thanks to all of you experts! Jay
:) :) :) jayb, Where did you find the thread showing how to replace the dispenser assembly? Thanks.
It is on Page 17 of this manual
Originally Posted by: jaybgator  It is on Page 17 of this manual Jayb, Thanks for trying to be helpful to another DIY'er!! Looks like I have a different model #. Don't know if the instructions in that manual would apply to my unit, and I'd like to be sure I have the correct info before I start the dissassembly of the door. Were you able to find your manual online? Did you have to pay for it (I could only find a "for a fee" site that could provide the manual for my model #.)? If not, do you have a link to a site with service manuals for free? Thanks.
Thanks. No, but I think the manual is similar. If the dispenser part is the same the instructions should be the same. I found the same instructions in several threads for several different models.
Originally Posted by: jaybgator  No, but I think the manual is similar. If the dispenser part is the same the instructions should be the same. I found the same instructions in several threads for several different models. Also, I did not see service manuals for free anywhere. I happened upon that one somehow through another thread.
Originally Posted by: jaybgator  Also, I did not see service manuals for free anywhere. I happened upon that one somehow through another thread. Thanks, jayb!
