Hi there....I replaced the two ropes that engage the dishwasher door springs, everything is good except now the door pulls just a bit to the right,the center latch where the door locks top center is off just a bit when you close it. When you push it and shut it, it squares up , closes and locks but I'm concerned about this " pulling to the right ".....any ideas, put both on identically, make some sort of adjustment ? thx Paul
Yes I would check if the springs do have different settings.
Also check that the door hinges are OK |
THIS FORUM IS DEAD!!!!!!! |
