The timer know just spins whne I tried to put in a new load of laundry. It worked fine earlier in the day and now the know just spins, it is like it is not catching on anything. I also am unable to pull it out or push it in. Any idea what needs to be done to fix it??? :confused:
You will need to determine if it's the shaft in the timer or the knob itself that is messed up, timer part # AP2045964
Nat
How do I get the know off to determine if it is the knob or the shaft that is ghaving the problem?? I took the screws out of the top so the face plate is free, but how do I get the know off to determine the problem?? Do I need a special tool or is there another way to get it off?
THIS FORUM IS DEAD!!!!!!! |
