ghjkl
#1 Posted : Saturday, November 15, 2008 1:58:33 PM(UTC)
ghjkl
My washing machine will not drain. :mad: It runs through the entire cycle and does everything thinking that it has drained when it is suppossed to. During the previous cycle there was no problem noticeable, this started in one cylce.
What could be the cause - the power source is ok, the lid is closed all the way.
HELP!
libertyappl
#2 Posted : Saturday, November 15, 2008 2:00:44 PM(UTC)
libertyappl
Check your pump for an obstruction.
Nat
Washing Machine Will Not Drain On Any Cycle (Washer Repair)
by cather8402 6/12/2008 5:24:49 PM(UTC)
