AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer will not fill after replacing fill valve
Speed Queen washer will not fill after replacing fill valve
Originally Posted by: toddf  Speed Queen washer will not fill after replacing fill valve Todd, A model number would be a lot more helpful. In general, if you've replaced the fill valve, and you have no broken, loose wires, the next step is to test: the lid switch, then the water level switch, then the timer circuits in the fill increment. :cool: :cool: :cool:
Washer Repair
