tnirp844
#1 Posted : Friday, December 3, 2010 4:36:37 AM(UTC)
tnirp844
On this model, do I remove the front or back of unit to replace and inspect belt and drum roller?
kayakcrzy
#2 Posted : Saturday, December 4, 2010 2:57:26 AM(UTC)
kayakcrzy
On this model, which is a front loader, just take off the bottom front panel. There will be 2 or 3 screws on the bottom of the bottom panel. Then look in there. Actually if the belt was broken, you would be able to program the dryer, but, when you hit start nothing. Because there is a belt switch. So if the belt is broken, it won't run at all. Tom ApplianceEducator.com
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
how to access dryer drum belt (Dryer Repair)
by Mikey3160 11/29/2017 9:47:44 AM(UTC)
Drum belt idle wheel (Dryer Repair)
by asaw11 10/2/2015 12:38:36 PM(UTC)
Maytag Dryer; Drum belt sliding off the pulley? (Dryer Repair)
by yzl 1/28/2012 8:56:25 PM(UTC)
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? (Dryer Repair)
by Darrel Hedman 5/11/2011 4:48:44 PM(UTC)
Dryer Nearly in Flames After Changing Drum Belt (Dryer Repair)
by NotMrFixIt 12/11/2008 10:11:37 PM(UTC)
Drier drum belt how to start in the back or front??? (Dryer Repair)
by White westinghouse 12/5/2007 11:22:37 AM(UTC)
how do I remove the metal cabnet and repace a new drum belt (Dryer Repair)
by Tinas7 11/12/2007 4:09:45 PM(UTC)
cannot put drum belt back on tight (Dryer Repair)
by frank 8/7/2007 6:50:19 AM(UTC)
