mitchweisman@yahoo.com
#1 Posted : Friday, November 14, 2008 6:16:37 PM(UTC)
The ac :) works but no heat:(
icehouse
#2 Posted : Saturday, November 15, 2008 3:04:52 PM(UTC)
icehouse
Fusible link, limit switch, heater coil. Check all with an ohm meter.
http://forum.appliancepartspros...continuity-ohmmeter.html
HOME RENONVATION SERVICES
#3 Posted : Tuesday, November 18, 2008 11:01:55 AM(UTC)
I had the same problem, check the the overload protector, you will find it just above the heat coils, there are two of them, check the last one close to the heat coils. the part number for zoneline 3500 is wp23x10020 (ge part number) or ap# is ap3188632
GE Profile gas range will not heat up for any 'Bake Functions' (Oven Repair (including Ranges and Cooktops))
by pjh01 4/24/2011 7:46:21 AM(UTC)
Whirlpool range will not heat at all (Oven Repair (including Ranges and Cooktops))
by epdavis23 10/23/2008 11:49:13 AM(UTC)
