there is no water going to the ice maker, but i do have water going to the outside water dispenser on freezer door
Originally Posted by: thecass2 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) there is no water going to the ice maker, but i do have water going to the outside water dispenser on freezer door Did you ever find out what this was? Water inlet? I'm having the same problem.
Originally Posted by: thecass2 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) there is no water going to the ice maker, but i do have water going to the outside water dispenser on freezer door What is the temperature in the freezer?
Originally Posted by: semicolon1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Did you ever find out what this was? Water inlet? I'm having the same problem. I had the same problem and heres what I found... I first checked the silenoid that the outgoing lines are attached to. You have 1 water line comming in connected to a valve with 2 outlets. (1 to the freezer and 1 to the water) each 1 of them are operated by a switch. If that switch is bad then it will not send water to that paticular line. Now, mine worked! But I still didnt get water to the freezer. After making sure the temp was at least 17 degrees (it wont start producing ice until it is "cold" enough) I found that I actually had a kinked line where it was connected to the outlet in the back of the refridgerator. Now after straightening out the kink, I am getting perfect ice. Hope this helps! Im not a technician just a doityourselfer.
