judesof1023
#1 Posted : Wednesday, December 1, 2010 7:16:11 AM(UTC)
judesof1023
please Help. I'm trying to replace the water lines in this thing....the water line starts in the back, heads left, (when looking at the back of unit) then goes up into the unit...and then back down next to that first line, then to the front. How do i get to the hose that enters up into the unit. Any help at all will help the prevention of me slamming my head against the wall.
Thank You.
magician59
#2 Posted : Wednesday, December 1, 2010 7:38:50 AM(UTC)
magician59
What is the problem that made you decide to replace the water lines?
judesof1023
#3 Posted : Wednesday, December 1, 2010 7:48:22 AM(UTC)
judesof1023
we are replacing because the "switch" in the back (where the copper line connects) went bad so during replacemnet the tube crumpled...i am now reading that the left line might be headed to a tank coil?
magician59
#4 Posted : Wednesday, December 1, 2010 8:07:53 AM(UTC)
magician59
Yes. the one on the left is the line that goes to the reservoir (coil of line) inside the fresh food section. Here's a replacement coil. It looks like there's enough of it that you might be able to transfer from inside to outside, depending on how much of the line needs to be replaced. You will need to remove the crisper drawer(s) to access the coil on the inside.
Part number: AP4133361
